Engine Working Fine.
No fault codes
Toyota Etios 1.3
Toyota Etios 1.3
- toyota etios 1.3.psdata
- (22.48 MiB) Downloaded 1586 times
Re: Toyota Etios 1.3
Converted file is attached.
Please inform what type of the pressure transducer you use,
if you have WPS500, it is required to use our WPS500 deep well adapter for correct measurements.
- toyota etios 1.3.mwf
- (19.73 MiB) Downloaded 1717 times
I am using the regular WPS500X
What kind of mistake can have in this case (this signal that i have aquired).
What is your "deep well adapter"?
Tks
Tks
I think standard Pico adapters don't work properly because of wrong construction.
There is a parasitic volume that distorts the measurements.
It's better to ask about WPS500 deep well adapter directly support@usbautoscope.eu
