Injectors Raster mode
In modern engine management systems, the control pulses for gasoline injectors are spaced in time.
Because of this, it can be difficult to compare their shape and duration.
Mode called Injectors_Raster.upc is designed to work with time-separated signals coming to different channels of the oscilloscope.
This mode displays pulses in the form of a raster, which allows to compare visually their shape and duration.
You can download a ready-made configuration file here
Injectors_Raster.upc- (853 Bytes) Downloaded 1159 times
pauloirogerio
Re: Injectors Raster mode
very good, I could do it in the ignition primary
https://SecreLocal.com - Video Chat Dating - No Verify - Anonymous Adult Dating - Live Video Chat
Yes, you can do it with the ignition primaryvery good, I could do it in the ignition primary![]()
Adelson Maurício
Se usar o modo injector Raster na ignição primária pode queimar a entreda do USB autoscope?
No, but the signal will be limited to 30V.
Muchas gracias! Muy útil!
Y por cierto quiero agradecer por el script que hicieron llamado "SignalDAFP".
Sumamente preciso y eficaz!
Habrá posibilidades que en algún momento se pueda por ejemplo agregar medidas o "measure" para podes ver medidas en tiempo real de cada canal tanto en el eje vertical de voltaje como el eje horizontal de tiempo?
[/quote]
Hello! How do we load the mod?
[/quote]
Hello Diogo! I have an adapter to Pin3/Bnc and i use the cable of laboratory scopes 10:1. And Change settings
- Pin3- bnc Adapter e.jpg (52.63 KiB) Viewed 9822 times
Can Injectors Raster mode be used effectively with other types of signals, like diesel injectors? Also, is there a guide for setting it up for beginners?
