Page 1 of 2
Injectors Raster mode
Posted: Tue Oct 13, 2020 11:31 am
by admin
In modern engine management systems, the control pulses for gasoline injectors are spaced in time.
Because of this, it can be difficult to compare their shape and duration.
Mode called
Injectors_Raster.upc is designed to work with time-separated signals coming to different channels of the oscilloscope.
This mode displays pulses in the form of a raster, which allows to compare visually their shape and duration.
- Injectors Toyota Corolla 1.6 2019.png (2.4 MiB) Viewed 37795 times
You can download a ready-made configuration file here
Re: Injectors Raster mode
Posted: Fri Oct 16, 2020 5:50 pm
by pauloirogerio
very good, I could do it in the ignition primary
Posted: Tue Oct 20, 2020 8:53 am
by admin
Yes, you can do it with the ignition primary
Posted: Sun Oct 25, 2020 9:47 pm
by Adelson Maurício
Se usar o modo injector Raster na ignição primária pode queimar a entreda do USB autoscope?
Posted: Thu Oct 29, 2020 12:55 pm
by admin
No, but the signal will be limited to 30V.
Posted: Sat Oct 31, 2020 6:35 pm
by Pablo Caballero
Muchas gracias! Muy útil!
Y por cierto quiero agradecer por el script que hicieron llamado "SignalDAFP".
Sumamente preciso y eficaz!
Habrá posibilidades que en algún momento se pueda por ejemplo agregar medidas o "measure" para podes ver medidas en tiempo real de cada canal tanto en el eje vertical de voltaje como el eje horizontal de tiempo?
Posted: Sat Apr 09, 2022 3:40 pm
by Pablo Caballero
[/quote]
Hello! How do we load the mod?
Posted: Sat Apr 09, 2022 3:52 pm
by Pablo Caballero
Posted: Sat Apr 09, 2022 4:39 pm
by Pablo Caballero
pauloirogerio wrote: ↑Fri Oct 16, 2020 5:50 pm
Hello Diogo! I have an adapter to Pin3/Bnc and i use the cable of laboratory scopes 10:1. And Change settings
Posted: Wed Dec 25, 2024 12:36 pm
by minakshi
Can Injectors Raster mode be used effectively with other types of signals, like diesel injectors? Also, is there a guide for setting it up for beginners?
