CHEVROLET ISUZU NHR REWARD 2022 Euro IV - Diesel Engine 4JH1-TCN - 2999 cc
Automatic analyzing the cylinder pressure waveform
BrayanArangoG
Post by BrayanArangoG » Wed May 14, 2025 2:26 am
Dear forum moderators, as I mentioned in my first post, in this second post I am sharing the pressure signals (channel A) and fuel injection signals (channel B) taken from the ISUZU 4JH1-TCN diesel engine. I would greatly appreciate it if you could convert the .psdata files to .mwf format for further analysis in the USB OSCILLOSCOPE software.
I hope that with these new measurements or with your help, I will be able to run the script correctly this time.
I appreciate any guidance you can provide on how to configure the options menu when executing the script in the USB OSCILLOSCOPE software, as I have confirmed that neither the sensor (WPS500X) nor the connection are defective after repeating the tests. Thank you once again for your time and assistance.
Sincerely,
Brayan Arango González — Mechanical Engineering Student, UdeA
Cilindro 4.psdata
(11.7 MiB) Downloaded 140 times
Cilindro 3.psdata
(12.24 MiB) Downloaded 159 times
Cilindro 2.psdata
(11.63 MiB) Downloaded 124 times
Cilindro 1.psdata
(6.34 MiB) Downloaded 145 times
Re: CHEVROLET ISUZU NHR REWARD 2022 Euro IV - Diesel Engine 4JH1-TCN - 2999 cc
Post by admin » Thu May 15, 2025 9:01 pm
Converted files are attached:
Cilindro 1.mwf
(5 MiB) Downloaded 95 times
Cilindro 2.mwf
(9.43 MiB) Downloaded 105 times
Cilindro 3.mwf
(9.93 MiB) Downloaded 112 times
Cilindro 4.mwf
(9.43 MiB) Downloaded 84 times
You can familiarize yourself with the capabilities of the Px script, which is designed for analyzing the pressure graph in the cylinder of gasoline engines:
https://usbautoscope.eu/library/px-script-manual/
