AJUDA COM PX FORD ECOSPORT.
Automatic analyzing the cylinder pressure waveform
Diogo_Vieira
Post by Diogo_Vieira » Mon Oct 14, 2019 2:34 am
ecosport duratec Px35+Longer00.mwf
(6.94 MiB) Downloaded 1126 times
OLÁ A TODOS.
PODEM ME AJUDAR COM ESTE SCRIPT?
(1) POR QUE HÁ UMA RAMPA ASCENDENTE NA EXAUSTÃO?
(2) POR QUE O VÁCUO PARECE SER RUIM?
POR QUE HÁ UMA OSCILAÇÃO NA RAMPA DE ESCAPE(3 NA FOTO)?
Ygryk
Re: AJUDA COM PX FORD ECOSPORT.
Post by Ygryk » Tue Oct 15, 2019 8:50 am
The pressure in the cylinder during the exhaust stroke (Fragment shown at number 1) will be at the level of the horizontal blue line only if the atmospheric pressure is equal to the normal atmospheric pressure at sea level (760 mmHg or 100kPa).
Most likely, you are not at sea level, but higher, and, accordingly, the atmospheric pressure in your region is somewhat lower. Therefore, the pressure graph here is slightly lower.
You are mistaken: here the vacuum in the cylinder during the intake stroke is in order.
The fragment shown at number 2 looks like a good motor.
The distortion of the pressure graph in the area shown at number 3 may indicate a weakened bronze bushing of the exhaust valve.
